| Hello! This is a very very interesting forum with a lot of useful information from very well trained and experienced people like you. I want to know if it's possible to enter in the andvanced menu of the dv 5100 to find out operation times (DH DRUM HOUR METER TH TOTAL DRUM HOUR METER PH POWER HOUR METER CH CAP HOUR METER LD LOADING TIMES EL EJECT TIMES HC HEAD CLEANING FR FWD/REV TIMESTOTAL DRUM HOURS, OPERATION HOURS, ERROR HISTORY) On the jvc gy dv 500 this is possible by pressing simultaneously LOG and MENU buttons Hope you'll excuse my ''french" |
| No problem 1. Set the POWER switch to ON.
SHUTTER dial.2. Press the STATUS button for 1 second or longer to display the TOP MENU screen. 3. Rotate the SHUTTER dial to select the OTHERS item, and then press the SHUTTER dial. ● The OTHERS (1/2) menu screen appears. 4. Select the NEXT PAGE item on the OTHERS (2/2) menu screen, and then press the SHUTTER dial. ● The OTHERS (2/2) menu screen appears. ■The accumulated drum running time is shown next to the DRUM HOUR item on the OTHERS (2/2) menu screen. 5. To return to the normal screen, use either of the following methods. ● Press the STATUS button or ● Return to the TOP MENU screen and then select the EXIT item from the TOP MENU screen before pressing the hidden service menu How to get to the menu?
| Thanks! Very interesting menu but still i couldn't find anyindication of total drum hours or power time. Only a lot of parameters from RGB gain, black, burst. It is a special item in the menu which has to be interpretated? Which one is it? Can you please tell me if the firestore hard disk can be connected to the gy dv 500 also and if it is necessary to open the camera case for mounting it? |
| Thanks! But i didn't found the TOTAL DRUM HOUR or POWER HOURS indication. Only a lot of parameter settings like RGB, Black, burst etc. it is a special indication which i missed? Can you please tell me if it is possible to mount a firestore hard disk recorder on jvc gy dv 500 also? |
| Very interesting menu but no indication of total drum hours or power time its te only secret menu I know. Firestore on GY DV500 yes but no return vidéo on view finder and just synchro REC start work by firwire The connection between the GY-DV500 and the FireStore DR-DV5000 is a power connector and a 6-4 pin FireWire cable. Comminucation such as record triggers, AV/C control, timecode and DV audio/video all are passed via the FireWire connection. On the Focus support website, you can download the DR-DV5000 QuickStart guide which details the mount process to the compatible JVC cameras. on 5000 5100 there is more control of firestore by camcorder Citation:
| yhnx again sorry for the double post. Did you found out the total drum hours indication? |
| Mots-clés: jvc |
| VS DRUM vol1 un battle de batterie epoustoufflant | bassman | Faire son film | 17 | 26/11/2006 23h25 |
| Français total... | Gwenn | Sony Vegas - DVD Architect | 6 | 01/11/2006 14h33 |
