Vieux 05/05/2007, 10h19
Avatar de Marc
Marc Marc is offline
Consultant technique Canopus
Par défaut Sony DCR-TRV265E - erreur : E:61:10
Un message de Tiana :
Une erreur s'affiche sur l'ecran du camera Sony DCR-TRV265E et qui est "E:61:10".
Merci de bien vouloir m'aider à resoudre a mon probleme.
Vieux 05/05/2007, 10h56
Par défaut Re : Sony DCR-TRV265E - erreur : E:61:10
c'est une erreur de la partie optique AF ou Zoom
solution une bonne claque sur l'AR du caméscope ...
vu sur les sites US
chris
- 1st May 2004 6:59
the two good smacks works!!!!!!!!!!!!!!!! i was in LA all week for work and thur the error code came on.... shit! looked up a code on sony.com - no help found this forum - thank god two good smacks with the power off and poof....she works and the focus works agian... thank tou all at tech support . keep up the great work. chris
31st Dec 2005 4:41
Yes folks...it sounds absolutely rediculous...but it worked for me too. Turn the camera off and give it two smacks and WA-LA the error message was gone. I started off with two pretty light smacks on the back of the camera and worked my way up to what I would consider two medium hits with a power down inbetween each double hit. It only took three attempts...but I was being pretty gentle in the beggining. If you look in the Ops. Manual it says you have to contact a Sony Dealer/Authorized Service Facility....it is a camera malfunction that you cannot reverse.....THEY ARE LIARS....he he he...The Fonz ROCKS!!!
Kathleen - 14th May 2006 15:56
YUP - The two good smacks worked for me and my E61:00 error code - incredible!
17th Oct 2006 3:31
Thats amazing! My is about 3 years old and I have never had any problems with until today. I was so not happy but I got home and googled this problem and I be darn 2 smacks on the top of the LENs assembly unit they were hard enough to make the flash assembly open up. But I turned the camera on after and my zoom is working again. I even took some photos of my tabby cat. Thanks for the information.
3rd Nov 2006 17:15
E:61:10 - The Most Stupid Error I am from India. I have DSC T33. I had the same problem - E:61:10 I went to Sony Authorised Service Center. They told me that we have to replace part no-16. The estimated cost was 10200 Rs (~200$)! I decided not to repair it Then I saw this site and decided to give a try. In the beginning i smack slowly because i was worried. after trying 10-15 min it was still showing E:61:10 error Now i was engry Then i hit it really hard in the back (LCD side) and when i start it the error disappeared!! Now it works GREAT. NO PROBLEM AT ALL!!
Ashley
- 2nd Apr 2004 3:03
After reading other emails on this same error message, I decided to follow the advice of one that did not require taking it to the shop and having it repaired. I hit the barrell against the table with two good whacks, and it the error message disappeared. The zoom now works and so does my auto focus and manual focus. Problem solved, believe it or not. I held my breath because I was scared I would break it, but now it's fixed.
etc etc ...
Erreur architect 4 socool DVD Authoring 0 29/01/2007 17h36
[DVD-A] Erreur à la préparation du DVD. Gilles FAQ Vegas & DVD-Architect 0 30/11/2006 21h55
erreur a l'encodage bragon DVD Authoring 1 30/08/2006 15h42
erreur dvd 19013 bragon DVD Authoring 0 08/11/2005 18h44
Fuseau horaire GMT +2. Il est actuellement 13h43.
