Précédent   Forums > Les news : Vidéo, MediaCenter, Home-Cinéma > Le meilleur du Web (en anglais)
Vieux 20/06/2008, 10h57
Avatar de 16RL
16RL 16RL is offline
vidéo depuis longtemps
Par défaut 13 minutes à couper le souffle !
Red Bull ne fait pas dans le spot tv traditionnel.
Ou la vie ordinaire d'un "Capetonian" (habitant du Cap, pas d'Agde, pas d'Aîl, mais plus bas, tout au fond).
http://www.hadlowpro.com/
Pour plus d'informations et de commentaires, récupéré d'une discussion sur le site de Vegas:
http://www.sonycreativesoftware.com/...991&Replies=13
A vos logiciels !
Vieux 22/06/2008, 22h41
Avatar de MANU-DMZ
MANU-DMZ MANU-DMZ is offline
Par défaut Re : 13 minutes à couper le souffle !
Superbe!!! Merci pour ce lien! Une excellente source d'inspiration en effet!
Vieux 27/06/2008, 12h58
Avatar de 16RL
Il y a bien déjà ce début d'explication sur le site de Sony:
Subject: RE: Beautiful editing
Reply by: GlennChan
Date: 6/13/2008 5:39:50 PM
(re: the bullet time-like effect)
I believe it's done through cutting out the different planes of depth and then doing camera projections. (Ack, not the greatest explanation.)
So you split up the image into two or more planes.
One is the surfer (sorry, probably not the right term).
The other is the ground. There will be a hole there so bits of it will be cloned/painted in.
Those two planes are stuck into a 3-D environment.
There are probably 2 camera angles. (More angles is better but I didn't see that many cameras.)
The camera move is done in a 3-D space (kind of like 3-D compositing in Vegas). Blending between the 2 camera angles is probably some combination of optical flow + paint work. The in-between frames are made up via optical flow (similar idea to face morphing stuff if you've ever seen programs which morph one face into another).
Certain semesters of fxphd.com go through this. I don't know of any free resources off the top of my head. But it's likely a combination of camera projection and optical flow + paint work. There is some camera projection information on Google.
2- If you look in the background of the shot I think you will see that it doesn't look right.
Et cet autre qui pense connaitre l'auteur:
Reply by: what the fx
Date: 6/19/2008 12:55:07 PM
I loved the whole relaxed look. Very inspiring
The kite and surfer had to be keyed
Boris does a very cool alpha key separation after looking at that clip I replicated the echo in Vegas [past 8 levels up an move each one in position} but only after I did an alpha key in boris as a plug direct
But the 3d pans fast to slow are perfect, need to suss that out. The water drops are easy enough [Mr Murcury ]Boris
The editor of that clip although shot in Cape town might be a Durban guy Zazman . D Zastron {we worked on some projects together a few years ago} has done similar stuff I will email him and see if he will post a reply here if anyone is interested.
Rory
Dernière modification par 16RL 28/06/2008 à 08h08.
Vieux 27/06/2008, 13h24
Avatar de 16RL
Sous cette fabuleuse vidéo la marque Flexifoil invite à en consulter d'autres concernant son matériel.
J'ai juste fait une capture à 1' 44" de la 3e icône "2008 Kitesurf Board ..."
Nom : kite surf.JPG
Affichages : 191
Taille : 22,9 Ko
... Et d'autres de dédoublements multiples (à 2' 56" parf exemple), de gouttes, ...
Emission 13 minutes tous courts mitchoumpr Faire son film 0 30/01/2008 15h23
QUESTION PC: les ventilos de mon portable tournent à fond après 5 minutes ! Xl1s'iste PC - Stations de montage - Windows, Linux 38 28/10/2006 02h12
Appel à la participation pour un test de 3 minutes. JC29 Le bar de la Marine 27 31/01/2006 19h39
Couper le cordon... CameraCrew Audio (prise de son, montage, mixage....) 9 27/08/2005 10h34
Fuseau horaire GMT +2. Il est actuellement 12h07.
