Une nouvelle mise à jour est dispo (6.0d); * Support for VR-mode DVD Handycam® camcorder discs has been improved. When importing video from Sony DVD Handycam discs in VR or Video mode, each chapter is now imported as a separate file. * The MainConcept AVC/AAC codec has been added to Vegas. You can use this plug-in to import H.264 video in your projects and to render H.264 video (including support for HD frame sizes, two-pass encoding, main and baseline profiles, export to all common frame rates— including NTSC, PAL, and 24p— and Apple iPod® video format). Please continue to use the Sony AVC/AAC encoder to create video for the PSP™ (PlayStation®Portable). * Video quality has been improved for the Sony AVC/AAC encoder and rendering templates have been refined. * A problem has been fixed that could cause problems when reading AVI files with MP3-encoded audio. * A bug has been fixed that could cause Vegas to hang in some low-memory situations. * A bug has been fixed that could cause Vegas to crash after copying and pasting Bézier mask keyframes between events. * A bug has been fixed that could cause Vegas to crash when pressing Alt+Shift+4 to toggle external monitor preview when the Video Preview window is not visible. * A problem has been fixed that could cause nested projects to display the incorrect length. * Audio/video synchronization has been improved when reading certain QuickTime files. * High-definition Windows Media Video rendering templates now use the Windows Media Audio 9 codec for improved device compatibility. * A problem has been fixed that could cause a hang when burning a disc-at-once CD with the Plextor 716 SATA drive. * A display issue with Waves GTR plug-ins has been fixed. * A problem has been fixed that could occur when editing audio event properties on systems that use decimal separators other than a period. * A problem has been fixed that could occur when typing nondelimited timecode in the Vegas external video capture application in PAL format. * Various improvements have been made to the Media Manager. * A problem that could cause XFX audio effects to run in demo mode has been fixed. * Fixed a problem that could occur when running the Batch Render script without Quick Time installed. * Resolved an issue with recapture of media from an AAF import. * A bug has been fixed that occurred when setting the Timecode InPoint value of a media source during AAF export. * A bug has been fixed that could cause Vegas to crash when adding some MPEG-2 files to the timeline and converting YUV 4:2:0 color to RGB. * Last-used render templates are now preserved for each rendering format. * Issues with certain VST plug-ins that related to presets and settings have been fixed. * A problem with the ripple function sometimes creating very small event overlaps has been fixed. * Scripting: a problem has been fixed that could prevent RenderArgs flags (such as IncludeMarkers) from changing the render settings. |
Merci pour l'information.
J'ai procédé à l'installation de la release d de la version 6 de vegas, puis l'ai désinstallé d'urgence à cause de plantages intempestifs . En est-il de même pour vous ?
Je n’ai hélas pas trop le temps d’utiliser Vegas actuellement. Je n’ais donc fais la mise à jour que sur mon PC Internet et je n’ai pas eu de plantage pour l’instant. As tu remarqué si ça plantait lors de manip particulières ? Le rapport de l’erreur fait il référence uniquement à Vegas ou à d’autres DLL ? |
j'avais un plantage systématique lors de la sélection de l'onglet 'CD setting' dans le menu des préférences par exemple avec le message d'erreur commençant ainsi: Sony Vegas 6.0 Version 6.0d (Build 210) Exception 0xC0000094 (integer divide by zero) IP:0xC66235B In Module 'sfcd.cdd' at Address 0xC620000 + 0x4235B Thread: GUI ID=0x9C8 Stack=0x12C000-0x130000 |
A titre d'info : C'est normal qu'après mise à jour de Vegas vers la version 6.0d, mes icônes de fichiers Ac-3 sont ceux de DVDA ? Parcequ'avant c'était un Icône bleu velouté avec une sorte de spirale blanche. Moi j'aimais bien. (et c'était intiutlé : Ac3 encoded file.) et je m'y étais bien habitué. Stéph.B |
Pour moi, aucun changement:
Ah ben tiens alors... C'est bizard. Oui c'est ce que j'avais. J'ai restoré et effectivement sans la mise à jour j'ai bien cet icône que j'ai toujours eu d'ailleurs. Ca m'inquiète ça. Et si on clique sur propriété : j'ai toujours eu "s'ouvre avec DVD Architect" quelque-soit l'icône. |
Tu dois pouvoir changer l'icône en éditant la clé de la base de registres: HKEY_CLASSES_ROOT\ac3\DefaultIcon et tu pointes vers un des répertoires C:\WINNT\Installer\{xxxxxx-xxxx-xxxx-xxx-xxxx}\ac3.ico,0 (tu cherches dans lequel tu as l'icône). |
oulah. Gilles c'est très fort ce que tu me dits de faire. J'y connais absolument rien là dedans. Pour l'édition de la clé de la bas de registre : comment ouvre-tu HKEY_CLASSES_ROOT\ac3\DefaultIcon. ? PS : j'ai bien "application inconnue" sur mon vieux PC et le bon icône. Mais sur mon PC de montage non. Je vais recommencer l'installation. On sait jamais mais il y a un pb de toute façon dès le départ. |
| Tags: vegas |
| mise à jour première pro | Uniweb | FAQ Première Pro | 2 | 11/02/2007 17h58 |
| Mise à jour Connect HD 2.1 | Gilles | Sony Vegas - DVD Architect | 0 | 17/12/2005 09h07 |
| mise à jour Avis pour mac os X (10.4.2) | nono44 | AVID | 0 | 04/09/2005 00h03 |
| AVID : mise à jour Xpress Pro HD 5.1.4 pour PC | Uniweb | Les news de la vidéo | 1 | 15/08/2005 17h34 |
| AVID : mise à jour Xpress Pro 4.6.6 pour MAC et PC | Uniweb | Les news de la vidéo | 0 | 12/08/2005 10h34 |
