| convertir du video m2t to wmvhd avec vegas ... salout a tout les mond, je suit nouvaux scuse moi pour mon francoise tres alementer enfantil. je avet un tres important question. je reprend video avec mon camera hdv sony hc3 et capture mon video fiche m2t avec ( sony vegas 7.0c) or ( cine form direct hd release 3.0) je voudrait convertir mon video en wmvhd 1280x720 progress pour regarde sur mon monitor lcd. i have fait the export directament par vegas or procoder 2.01 les fruit de la conversion se ne pas bonne puor le video in moviment :-(((( je veue boucoup des problems sur ca tipylogie des image. je pens at un problem du interlecemant des image. je espere a votre conseil . merci boucop a tuts a bientot marco ![]() |
| je avait regarde en internet a ca solution ecrir en angle pur vous il 'et a bon alternative a bon solution ?? merci a touts marco i see this message from internet. i have been working with sony hc1 for a few month now and i ' find it very difficult to get a GOOD looking deinterlacec video without jaggiies, while preseving image detail. i 'm currently using premiere pro 2.0 and build in deiterlacer (like most deiterlarcers) just sucks. i've got a pretty good solution , but it's not very user friendly: edit in premiere pro 2.0 (i think same for vegas 7) export the video from premiere or (vegas) by frameserver debug in 1440x1080i open frameserver file in virtualdub use the smartdeinterlace plugin for virtualdub to deinterlace. lancsoz 3 resize tot 1280x720p in virtualdub use another frame server (avisynt) to export from virtualdub. openavisynt with adobe procoder 2 canopus to compress the resultate tiìo wmv9 hd. as you see, this is not the most ideal solution, but i've found that de smartdeinterlace plugin for virtualdub in combination with the excellent lancsoz 3 resize offer far superior image quality compararated to any other deinterlace resize tool i've tried. unfortunately, virtualdub does not support wmv , so that's why i frame server the deinterlaced and resized video to canopus procoder 2. as you might understund , i ' m still lloking for a more userfriendly solution. bye marco ![]() |
| je avait recevut ca solution par des outre outilizer du hdv une autre possibilité pourrait être d'utiliser Windows Media Encoder (gratuit sur Windows Media Encoder) A condition d'avoir aussi installé Windows Media Player 11, il est possible de convertir directement un fichier HDV au format .mpg (Program Stream). Apparemment, WM Encoder n'accepte pas les fichiers Transport Stream tels que .m2t, mais il y a plein d'outils pour passer de l'un à l'autre de manière non destructive (ou utiliser CapDVHS pour numériser directement de la HC-3 vers .mpg (PS)) WM Encoder permet de conserver ou désentrelacer la video à convertir. Attention de choisir le codec video Windows Media Video 9 Advanced Profile J'ai déjà obtenu de très beaux résultats en convertissant du HDV vers 1024 * 576 ou 1280 * 720 désentrelacé pour utilisation sur PC ------------------------------------------------------------------------ tant que le fichier de capture .m2t n'est pas lu de façon satisfaisante sur l'écran lcd (avec Vlc ou Media Player Classic, avec désentrelacement "bob"), il y a peu de chances d'améliorer le résultat final par quelque désentrelacement que ce soit : réduire le nombre de fields/champs /trames de 50 par seconde à 25 ne peut que faire empirer les saccades. Ce n'est que du côté de la prise de vue que l'on peut significativement améliorer l'image finale (peu de zooms, de panoramiques.. avoir au moins deux caméras rigoureusement sur pied ...). Note : il semble bien que Media Player Classic tienne actuellement la corde pour être désigné meilleur "player" -------------------------------------------------------------------------------------------------------------------------------------------------- Thanks for writing. To do this conversion is pretty difficult. We tested probably 20 different versions of our conversion workflow to get our current results. While we can't reveal the exact details of what we are doing, we can give you a few tips: 1.) try using Microsoft's free Windows Media Encoder: http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx We have also tried ProCoder and encoding internally with Sony Vegas and Avid Liquid but we get the best results from Microsoft's encoder. 2.) after lots of experimenting (and looking at what others do) we've found that the (video only) data rate you should encode at is about 8Mbps for 1080p video and about 5Mbps for 720p video. 3.) try to process your video in as few steps as possible. Every step of processing reduces video quality. If you do just a straight capture->encoding you should see pretty good results. Dernière modification par HDV_HC3 08/01/2007 à 23h38. |
| Mots-clés: convertir, m2t, vegas, video, wmvhd |
| convertir du video m2t to wmvhd avec vegas ... | HDV_HC3 | Haute Definition (HDV, DVCPROHD, XDCAM) | 2 | 08/01/2007 20h45 |
| titres avec VEGAS 6 | Frédo51 | Sony Vegas - DVD Architect | 13 | 05/12/2006 11h20 |
| Debuter avec vegas 7 fr | JMarc74 | Sony Vegas - DVD Architect | 16 | 01/12/2006 19h50 |
| Avec les cartes ATI : AVIVO pour convertir plus vite vos fichiers vidéos | Uniweb | Les news de la vidéo | 6 | 27/10/2006 23h47 |
